Massey 44 special 3 point help needed!!!
Hello everyone,
I picked up this Massey Harris 44 special gas a few months back. I've been having a issue with the three point. When I bought the tractor they
never used the three point so the ram shaft was rusted and pitted bad. So I took the ram off and sent it out for a new rod and they repacked the
ram and put new seals in it. I put the ram back on the tractor hooked the lines up the way they were on it before and it pushed the ram all the
way out and won't pull the rod back in. So I took the control valve the one that bolts to the side of the ram apart. Replaced the o-rings inside
and put it back together. Same thing still happens. Now I'm wondering what my next step should be any help would be appreciated thank you.
THERE IS A SCREW ON THE BACK OF THE CYL THAT CONTROLS THE THREE POINT OR THE HYD AUX HOSES. YOU TURN IT IN OR OUT FOR WHAT YOU WANT, IS IT IN THE RIGHT POS. FOR WHAT YOU NEED
I did find that screw and turned it and it did nothing. No fluid came out of the aux hoses when I removed the caps either.
