Massey Ferguson 35 weight
Do they make front wheel weights for a Massey Ferguson 35. I'm wanting to add a little weight to mine. What's the best option? Thanks
Yes:
Weights were available for the front wheels of the MF 35:
Item # 35:
Bob..
I see them occasionally at swap meets. Seen them for $100 up. Last one Tony picked them up. He may sell if he see's this. May take time but there out there. Also seen them on Photo Ads.
Yeah I got a couple of these half round sets, other tires I had filled with solid rubber, which is sometimes $150 a pair, and will only last as long as the rest of the tire, but I do like filling them with solid stuff.
A set from a Massey 510-410 combine should be the same, if your MF35 has 16" rims, and that should be pretty common to find at a salvage yard.
I have a pair , they certainly work well . There are also external ones that can be fitted in conjunction with the inners , they look fairly ugly though .
