Massey Ferguson 35X Multipower Lower/No Compression
Hello - we are getting ready to work on a MF 35X with Multipower. The owner's complaint is Low compression on 2 cylinders, and no compression on another. To his knowledge, the tractor has never had engine work.
Can someone point me to a good thorough service manual that I can purchase for this tractor?
Thanks,
Nate
This MANUAL is a MUST:
The MANUAL shown is not a REPRINT.
All MF 35 X OWNERS and REPAIR personal should receive one for Christmas:
E-bay had REPRINTS:
Bob..
(quoted from post at 13:21:52 12/09/15) This MANUAL is a MUST:
E-bay had REPRINTS:
Bob..
Does this one look correct? It has the matching #'s to the manual your pictures show.
http://www.ebay.com/itm/Massey-Ferguson-MF-35-50-Tractors-Service-Manual-/161846989814
Blown head gasket caused by a dropped
sleeve? I had one in here a couple yrs
ago, it also had a buggered crank as the
thrust bearings were in the pan. Good news
is a new crank is cheaper than servicing
the old one.
This Manual is on E-BAY:
It is listed as the SAME MF PART number as my Manual:
Is it the correct manual that you require? It is the same part number.
Picture/contents are the same as my Manual.
Bob..
(quoted from post at 18:40:33 12/10/15) Blown head gasket caused by a dropped
the old one.
We'll find out soon. Who did you use for parts on this engine?
It looks like a Perkins Diesel A3.152 engine.
(quoted from post at 11:17:36 12/15/15) On the a3.152 the injectors are straight up out of the head(indirect injection), on the ad3.152 the injectors are in at an angle.
Confirmed A3.152 with vertical injectors.
We found a crack in the head, orange peel pitting under the #2 cylinder along with ~100 PSI compression test result on #2 as well. Liners look like they need to be replaced also.
(quoted from post at 17:30:36 12/15/15) Is this engine CHROMED LINERS and Steel Rings OR Steel Liners and CHROMED rings?
Bob...
We don't have the liners out of the block yet. From what I remember, the chrome/steel liners and chrome/steel rings have different flange thicknesses usually? Other than that, is there a way we can tell?
- Nate
31358308 (3) Liner (Up to Serial or Engine Number 1935853)
82136 (3) Piston (Up to Serial or Engine Number 1935853)
31358322 (3) Liner (From Serial or Engine Number 1935854)
81874 (3) Piston (From Serial or Engine Number 1935854)
(quoted from post at 18:50:28 12/15/15) 31358308 (3) Liner (Up to Serial or Engine Number 1935853)
These are Perkins part numbers.
(quoted from post at 22:30:02 12/15/15) Pic.taken from an ORIGINAL SERVICE MANUAL:
My 35 X has Engine SERIAL # 1968212
Bob..
Tractor Serial Number: SNMY W386131
Engine Serial Number: 19E9136 C
(Pictures on their way)
Would you know what the "W" in your TRACTOR serial # represents? "W" Multipower?
Would you know what the "E" in your ENGINE serial # represents? "E" ?
Thanks
Bob..
My 35 X was shipped to Canada from England "SNMY320137" Engine S# 1968212C but no "W" and no "E"
(quoted from post at 15:12:29 12/16/15) Would you know what the "W" in your TRACTOR serial # represents? "W" Multipower?
Thanks
Bob..
This is what I'm having trouble with...I have a service manual here, but nowhere can I find the "W" and "E" in serial number breaks!!
I'm trying to locate a correct cylinder head for this tractor (and parts for an in-frame engine overhaul and complete engine overhaul, as this is what we found...(see picture)...
SERIAL NUMBER PREFIXES USED ON LATE MODEL FERGUSON / EARLY MF TRACTORS:
S - Standard/Utility Chassis:
G - Gasoline:
F - Single-stage Clutch:
C - High Clearance/High Arch:
H - High-altitude Gasoline:
M - Dual-stage Clutch:
R - Row-crop twin wheel:
B - LP Gas:
Y - Differential Lock:
T - Row-crop single wheel:
D - Standard Diesel:
W - Multipower:
J - Industrial/multipurpose:
N - Perkins Diesel:
V - Vineyard:
K - Vaporizing Oil (TVO):
L - Lamp Oil:
(quoted from post at 11:58:11 12/17/15) SERIAL NUMBER PREFIXES USED ON LATE MODEL FERGUSON / EARLY MF TRACTORS:
G - Gasoline:
B - LP Gas:
W - Multipower:
N - Perkins Diesel:
V - Vineyard:
L - Lamp Oil:
Well look at that! Thank you!
Any idea what the "E" is in engine serial number? [Engine Serial Number: 19E9136 C] I noted that most of the engine serial numbers in my service manual & in online resources usually have a "3" where there is an "E" in my serial number. This is why I'm having a bit of trouble picking out engine parts...
