Finally got my lift cylinders loose, now I need to find a place to buy seal kit, there are no MF dealers anywhere in my area. I
have not tried to move the ring ontop the cyl shaft yet, anyone recommend what tool to use, bent pick, small screwdriver or what. I can't see inside the port for the fender & tire so I removed the bottom pin lift arm,cyl support, two lock bolts on cross shaft and when I get help we will take the assembly off and lay it down where it can be worked on. But need to have the parts here before I start.
