Sediment bowl
Jlsmith
I am ordering a new sediment bowl for my massey harris 22 ordered one from agco. It is the bent style handle for one tank. What is the difference from the bent style handle and the t handle style.
On my TO35, the old sediment bowl with the "T" handle had a reserve so that if one opened it up fully, one had access to more gas in the tank. This was meant to aid those who ran out of gas in the field. By opening it fully, the drain reached lower gas levels in the tank. When I replaced it with the bent handle, no such reserve is offered. But the fittings are the same. I assume the design hasn't changed in the 10 years or so since I changed the bowl.
If the sediment bowl has two tubes (short--long)coming out where you screw into tank it will have the
reserve. I see several brands pictures that don't have them. Some do. Guess they save money and think
there is no need for it since the tractors are not used for farming as years ago.
