okierob
How do you tell which perkins diesel engine > it is a 1960 model is all the information I have from my friend.
1960 should be the indirect injection engine. The injectors are vertical. Direct injection came along in 1962 I think. The injectors are at a 45 degree angle.
(quoted from post at 17:09:37 11/22/15) I need to know how to tell if it is a 192cid or 203 cid
Look at the oil pan, is it one piece, or does it have what looks like a pie shaped looking piece between the oil pan, and the bell housing. If it has the little pie shaped piece its a 192, if its one complete piece its a 203.
It's not mine , but a friend that acquired it with some property. Apparently it has the 2 piece oil pan with the wedge. Thanks
