SiskiyouMH50
New User
Gentlemen,
Like the subject line says, we sheared a pin off between the lift clevis on the upper joint of the 3point hitch. The pin goes into the top of the housing under the seat.
I would like to know what part# for a replacement.
Also, is there supposed to be a spring around the pin just inside the housing??
Lastly, what does the pin do when the hitch puts pressure on it in the full up position?
Any input is appreciated, and please be kind as I'm sure you can tell... I'm not too savvy with tractors...
Thanks much
Thanks much
