MH50 sheared off pin behind lift clevis
SiskiyouMH50
New User
Gentlemen,
Like the subject line says, we sheared a pin off between the lift clevis on the upper joint of the 3point hitch. The pin goes into the top of the housing under the seat.
I would like to know what part# for a replacement.
Also, is there supposed to be a spring around the pin just inside the housing??
Lastly, what does the pin do when the hitch puts pressure on it in the full up position?
Any input is appreciated, and please be kind as I'm sure you can tell... I'm not too savvy with tractors...
Thanks much
What your telling me is the Plunger Draft Control. Has large spring around it?? 182580M1 is part number for Massey. --1.865 OD--Sparex Number S3350 in stock. Most parts dealer will not have it. About $20. Go to AGCO Parts Book .com and you can view as guest and look at break down of parts.
Miner09,
Thanks for the response and the description. We'll hunt the parts down and get it put back together.
Best Regards
PART # 182580M1 is ITEM # 7 of the MF 35 Diesel & 35 Gasoline tractor.
Same PART # as MH 50
Bob...
