Got my AD3.152 back together,should I retorque the head bolts!It has run about an hour with two new pistons and liner,runs great! I ordered a new head gasket from local dealer and the one I got was composite gasket,the one that came off it was copper,seems to be a very slight seepage from gasket from right side but none from Injection pump side of head gasket! I followed Massey Ferguson service manual on head bolt torque that showed 70-75 ft lbs of torque,also painted the gasket with several coats of aluminum paint thought that might help,but if I retorque and that does not stop the seepage may have to go with a copper gasket!It is not leaking from valve pan gasket,I have checked that,the head is dry below valve pan,it seems to be a very slight seepage from between block and head only on the lifter side!Has anyone run into this before using composite gaskets on these engines? Thanks!
