Dirtrancher
Hello,
I am trying to bleed the fuel system on a MF 3165 with a Perkins AD4.203, and could use your help.
Pumping the manual fuel lift pump results in very little fuel coming out, less than a teaspoon.
It's a new pump. The valve from the fuel tank is open, and the sediment bowl is full.
At this rate it will take hours to bleed the system. Any suggestions?
Thanks in advance.
-Dirtrancher
Thanks in advance.
-Dirtrancher
