Ferguson FEO 20 Sickle Mower
ropeford
New User
I'm new. I picked up my Dad's old Ferguson FEO 20 mower yesterday. It replaced the horse drawn one with the tongue cut down to pull with a Ferguson 30! Been a looong time since I saw or used it. Late 50's I guess. I saw something in a forum about an on-line operators manual. Does anyone know how to find one that way or any other way? What pins or bolts will work to attach the arms to the axle brackets? Any other help would be appreciated. Will it work on a later Ford Tractor like a 4000 or 5610? Thanks
No they will not work on the newer tractors as the lift arms are not made same way and the geometry is all wrong if you could modify and make brackets. The brackets on the mower are mounted under the axle of the 30 with the fender bolts, you might have to ge a half inch longer bolt but what is there already might be long enough.
