3pt 204 workbull
Tom Adams
New User
I have a 204 workbull hydramatic and the 3pt don't work. Wont go up or down just stays down don't know anything about it and help would be greatly appreciated. Thanks
That happened to our 135, it turned out to be the control valve that went faulty. Apparently it is the most common cause of the 3 point neither going up nor down in an MF.
Was it working then just quit or did you get the tractor with it not working?
My 202 has always had a backhoe on the back so the 3 pt. is very stiff. I need to replace the hydraulic pump before I can even test it but I'm sure it will need at the very least a good cleaning.
The more details you can give the better answer you will get.
Hi Tom, Is the 204 new to you? You must have the
instant reverse pedal in gear for the 3 pt to be
actuated.With the hyd lever up push on the fwd.
pedal and see if it comes up. Chuck
i have a 204 wb and when i start the engine the 3pt work even if the tractor is in neutral have you checked the fluid level i would guess it is pump related have you tried to put both lever on the high setting which is the far back position
I just this tractor sunday and the guy I got it off if said it works when it wants to. But I haven't had a chance tocheck anything on it but I tried everything Sunday and it wouldn't move. I figured maybe a filter and fluid swap and see how that works what di you think. And thanks for all the help
(quoted from post at 11:04:03 06/14/11) I just this tractor sunday and the guy I got it off if said it works when it wants to. But I haven't had a chance tocheck anything on it but I tried everything Sunday and it wouldn't move. I figured maybe a filter and fluid swap and see how that works what di you think. And thanks for all the help
Did you get it fixed? mine is doing the same thing. Thanks
