Zenith Carb
I have 1969 massey ferguson 135 with 3cylinder perkins gas has a Zenith Carb the float out of adjustment gas coming out of the bottom brass vent thing. Does anyone know what the float measurement is? Pictures would be great. Your help is appreciated. Regards Dwayne
Could be a sticking float needle. Try cleaning the needle-seat with a qtip on your drill with a brass cleaning liquid.
I think it's 1/4" when turned upside down from carb. Your float could also be scrubbing the sides or have a hole. More
than likely you have rust particles causing needle to leak and will require cleaning filters.
