40E with MF 11HD back-hoe
I have a MF 40e tractor with loader and a MF 11HD back-hoe. The pivot for the back hoe is cracked where the boom pins in. I would like to remove the pivot so I can replace it with a new one or send it off to have it welded/repaired but I can't find out how to remove the main pin. Can anybody help me?
Couldn't find any MF11HD backhoe, looks like you have a MF54A back hoe with the rotary cylinder. I should have one pin on top, one pin on the bottom.
Thank You!!! You guys on Yesterdaystractor.com are it!! I've spent about 3 hours on the internet trying to figure what back hoe is on this tractor. Looking it up on Agco parts book shows it as a "Centre mounted digger" but the parts didn't look right. The tag on the hoe I could not read except for the stamped model number and serial number. Know I have an Idea on how to drop the pin.
I do have another MF tractor with the rotary cylinder so I know what style you were referring too.
Thanks again ptfarmer!
