Ol' Time MF Fan
New User
Hello fellow tractor owners!
First a little about myself. I'm a fan of all antique tractors but my faves are the old Fords and MFs. I have a Massey 135 Diesel that I rebuilt from the ground up, with help from a pro on the engine and hydraulics rebuild. Everything on her was either replaced or rebuilt /restored & repainted. I believe it's a 1965 model the same as me.
That was a little over ten years ago when I restored it. Time to go through it again now unfortunately after making the mistake of letting my brother use it one day after it'd been sitting too long, and I didn't make sure it had enough oil in it first.... grrrr.
Anyway that's another thing I'll be getting to as time allows. For now I have a question about another Massey a buddy let be borrow to bush hog and move some logs & dirt around with while mine is down. This one's a 231 and yesterday when I was using it I had it in fist gear, shifted from neutral to low speed after taking a break to reset my logging chain, then let out the clutch and forgot to take off the parking break. To my shock & awe I heard the telltale POP sound the drive coupler or "shear coupler" (as I've seen it called after some research here) makes when it goes. Now it won't move in any gear, forward or reverse.
Apparently this happens from time to time although I don't understand how the thing could be made so weak that a simple mistake like that could take it out of commission?
Now for my main question and thanks for reading through my introduction. I have seen different threads saying I can get it out and replace it going through the top, or from the side at the PTO lever cover plate. The side looks like much less of a hassle to do, especially out in the field. Can I do it this way on this particular model and does the fluid need to be drained first? I have ordered the new coupler this morning and it should get here by the weekend.
Thank you for any advice guys. I borrowed this tractor and want to be responsible and fix what I broke, intentionally or not. Wish I could say the same for my brother about my baby. :x
[/img]
[/img]
