M/f 135 external pump mounting help
chas59
New User
I bought a front end loader for my 1971 m/f 135. it comes with a external pump, does anybody have any pictures or solution on mounting and running the pump.Thanks
To start with, because the crank hole was obsolete, you will have to take the 'chin' off. the tin under the grill. You might need to take more tin off as you play legos with your new pieces.
If there is a model number on the loader, google it. But there was so many welded up and 'modified' over the years, it may not go on that easy. Can you post some pics of it?
