need a photo please
rnccen
Can someone please post an image close up of a 135 MF Diesel on the left side looking at the fuel lines going from the filters forward in and around the exhaust manifold and over to the injector pump.
I don't think run correctly as 2 touch the exhaust manifold between the block and the inside space of the manifold and they are really tight.
Thanks
Paul
Hello Paul,
There is little room for the injector lines between the branches of the exhaust manifold.
They must not make contact with any part of the engine. The lines from the filters forward
are roughly horizontal and should be well clear of any part of the engine. Are they the
original lines? Have they been replaced with ones which are too short and have been made to
fit?
Hope you can see the pipe layout from my 135 when it underwent a second refurbishment.
DavidP, South Wales
(quoted from post at 09:07:21 09/29/15) Hello Paul,
fit?
DavidP, South Wales
Mine are original but they are very close to the exhaust manifold where the exhaust meets the manifold coming from the filter...it looks like mine just need to be straightened a bit as they are similar to yours but not quite horizontal.
Thank you for the photo.
Paul
