mark deiss
New User
Anybody have a source for a water pump, water pump kit, and part numbers for either for a Massey Harris Pacer (No 16) tractor.
For replacing the water pump, do I need to get any additional gaskets? Don't know how the pump is mounted and whether gaskets would come with the pump or not. If need to get separate gasket can anyone supply the part number.
Anyone have any recommendations on what it takes to repair the water pump? Looks like have to remove front grille, then radiator with radiator mount shrouds in order to get at water pump. Does not look like there is clearance to get the water pump/fan assembly out otherwise.
Google is not turning up anything anything - part numbers may help though. Possible salvage from Wengers, Kessels, or Burch. Maybe....
