150 Tune Up
What is the point gap and what is the timing on a MF 150 with a Continental gas engine? Also, is the timing mark behind the plug under the starter on the rear left hand side of the engine?. thank you.
If delco distributor has screw on cap points set at .022, if clip on cap points .020, flywheel timing marks are under the pop out plug below starter. If I remember right the timing is set at slow idle to 6 degrees BTDC.
