MF 35 power steering
Guys, I have used the classified section and called several salvage yards looking for complete power steering setup to put on my MF 35 with 3 cyl diesel, with no luck. Does anyone on here have any idea where these items can be found? I need the pump, hoses, and gear box. Thanks, Swede
Does your tractor currently have manual steering and you're looking to upgrade to power steering? I may know where there is a complete setup if you need it.
Looking to up grade from manual. Tractor steers hard and my shoulder problem is getting worse I have trouble turning it. Any help would sure be appreciated. Thanks Swede
The power steering conversion won't be cheap even with used parts. Replacement parts for the power steering on these can get crazy expensive. I took the power steering off mine because fixing it would cost more than I paid for my tractor.
True story. Looked into fixing the power steering on my 202 (similar to the 35) and decided to go a different route. Even used parts were unbelieveably expensive and new parts were non existent at any price.
I did it to mine. You will need the steering sector with all the hoses, the pump with either straight gear or spiral depending on whether the gear inside your cover is spiral.Hardest part is steering wheel removal.
The power steering mine had, had a individual cylinder on each side. So for the system I have you would need different steering arms on the spindles, and the brackets that bolt to the front axle for the cylinders. The stuff I have needs the valve in the steering column to be rebuilt (it leaks), needs new cylinders (they leak). The power steering pump I have needs a rebuild (worn), and all the hoses I have need replacing. The stuff I have is pretty much used up.
There is a bolt on aftermarket power steering setup for the 35, and 135, but I haven't heard much positive results about it.
You might want to look at Jackson Power Steering. Looks like it is what they specialize in.
http://jacksonpowersteering.com/category/products/
