Massey 204-found frost plug in rear differential
When changing fluids on the tractor, during the refill of the transmission and the rear diff drain plug out, the transmission fluid came out the diff plug. Removal of the PTO cover revealed a frost plug laying in the diff area. Where does this plug belong and how do you get access to it for reinstallation of a new one. Also, I was going to install a PTO, there appears to be a 2" plug of sorts inside where you would install the shaft? Any ideas.
Don't know about the plugs but if you install a PTO you need to realize that when you reverse the tractor direction the PTO also reverses. I put an over-running clutch on my 205 so I could use a hay tedder on it. Could be a disaster with some implements if you don't use the over-running clutch.
