OK, guys, I need some input on a charging issue. While brush hogging I noticed my MF35 gas was not charging. I headed to the shed. About three days later I took my voltage meter to check and determine what was going on. From what I can tell the battery went bad. I tried two different battery chargers and all went to max charge and just stayed there. Took the battery (under warranty) in and exchanged it for a new battery. Now I am still not getting any voltage from my GENERATOR. How can I check the unit before I take it off for a re-build? Do I need to re-polarize the generator? The new battery is now mounted on a rubber mat to lessen the stress of un-level ground. Bumps....
