Hydraulic Outlets on 231s
Alan V
I would like to ad rear hydraulic outlets to my 2000 model MF 231s. Is it possible to do this and, if so, how much work is involved. And of course, how much will it cost me?
It probably does not have an auxiliary hydraulic pump, so you use the 3 point lift pump(lower flow). You replace the plate under the seat with a selector valve. Make up hyd. lines to a pair of rear quick couplers of your choice. You cannot use the 3 point and remotes and same time, a lever on the valve selects one or the other. To get flow to remotes, put the 3 point lever in 'constant pumping' position.
This site sells the selector valve, as far as I know. We did our 253 Massey this way, works okay. We work a loader with ours, slow but we mainly use it feed round bales in the winter.
Garry
