Looking for a part for Massey Ferguson 135 - Diesel
rnccen
I have a cracked fuel line from the 2nd filter banjo fitting back to the tee. I have the part number 511888M91 and the dealer advised it is $125.00.
It is cracked at the banjo fitting head where the tube goes in. The pipe is rather short maybe 6" and I can't see spending that much on new part.
1. Does anyone know a source for used?
2. Since this is a return to the tee from the secondary filter, would I be able to remove the banjo fitting completely and put a bolt in and cap the tee on that side?
3. I saw in the parts book a single filter set up, has anyone converted from a 2 filter to a single filter set up?
Thanks in advance,
Paul
If it's the line I'm thinking don't remove it as it carries any trapped air out of the filter base before air can get to the injection pump, stalling the engine. Either repair it or find a good used one.
Found someone to solder the tube back onto the banjo fitting no more leaks there ... now onto the other leaks everywhere else :)
