I have a cracked fuel line from the 2nd filter banjo fitting back to the tee. I have the part number 511888M91 and the dealer advised it is $125.00.
It is cracked at the banjo fitting head where the tube goes in. The pipe is rather short maybe 6" and I can't see spending that much on new part.
1. Does anyone know a source for used?
2. Since this is a return to the tee from the secondary filter, would I be able to remove the banjo fitting completely and put a bolt in and cap the tee on that side?
3. I saw in the parts book a single filter set up, has anyone converted from a 2 filter to a single filter set up?
Thanks in advance,
Paul
Thanks in advance,
Paul
