massey 50 auxillary hydraulics
grtrnd1
Hello. I have a Massey Ferguson 50 with no auxiliary hydraulic setup. I just bought a new holland 472 haybine. I found a kit on ebay that includes everything needed to install auxillary hydraulics on my tractor for around 450 bucks. Is this tractor only capable of running a single line setup or is it capable of hooking up to a 2 line setup. My long term goal would be to get ahold of a vermeer 504f round baler with manual tie. I'm told I need a 2 line hookup. Is it possible to find what I need used or am I better off just getting a kit. Dont know much about auxillary hydraulics. Thanks in advance.
So you're saying I need a diverter vakve to take place of the stand pipe cover and a lone over to a 2 spool valve bank and 2 lines back behind my seat? Is one a return or will both be pressure? Thanks. Sorry for all the qiestions. Just want to do it right the first time
Yes, you put the diverter valve in-place the of the plate that the stand pipe goes to. Here is a setup for 2 cylinders you can run single action, and or two dual action cylinders (have 4 quick disconnects at the rear of the tractor).
