165 lift revisited
Hello all,
Thanks for all the responses to my lift problem. Got all the parts in, assembled, and the top cover back on yesterday. the lift works with the position and draft levers now, but need to make the final adjustments. This is where the problem comes in...
The repair manual says to attach an implement of 850lbs to the lift arms to make the neutral adjustment. Well guess what? I don't have anything that heavy. The heaviest implement I have is my 5 1/2' heavy duty box blade, and it only weighs around 3 or 4 hundred, if that.
How important is the amount of weight used?
Thanks,
Roger
Thanks Dieseltech. You've been a great help with this tractor and the WorkBull. Thanks to everyone else that added comments also.
Roger
