Trying to find MF 135 OEM seat assembly
Armymutt
Does anyone know where I can buy the parts to assemble a complete OEM seat for the 135? Mine came with an aftermarket seat that is way too close to the steering wheel. I'm 6'1" and am pretty crowded up on the controls. I prefer the look of the OEM seat anyway. Closest place I've seen one for sale is in the UK. Would like one that is in the US.
Just looked on the Agco parts site, there are three suspension seats for the US tractors, but each says to order the parts separately, have no assembly # that I saw listed. Any chance of finding a complete seat at a salvage yard?
Even ordering the parts separately would work. I'm not having much luck finding them. They are available in the UK here: http://www.silverfoxtractorspares.com/massey-ferguson-3565135-complete-seat-assembly-kit-13689-p.asp
I just pulled a complete assembly off a Massey Ferguson 88 Diesel and installed on my TEA-20. I no longer sit to close to the dash as there are several drilled holes in the seat mounting lower bracket that allow for several different positions of the seat parallel with the center drive train. I also installed a second complete assembly on my Massey Ferguson FE 35 X
Here are some part #'s and pictures. Notice the holes along # 28
Bob.......
My brothers 135 has the deluxe seat like John Deere D has shown. Since we are both 6' tall he cut a piece of 4"x4"x1/4" square tubing cut at a slant on both ends so the seat could be moved up, and back. Without the 4x4 tubing under the seat, the seat was too low, and too far forward.
My 2135 industrial came with a aftermarket suspension seat when moved all the way back was perfect for me. I also cut the center out of the stock steering wheel because the stock steering wheel was too close to the dash, and cab for me. I took a old 1964 Ford Falcon steering wheel, and bent the 3 bars to give it about a 6" dish, and welded it together. Now its away from the dash, and cab, and its in a much more comfortable position for me (hope you can see it in the picture below).
Here's a picture with the brush cab in its final position, you can see the seat, and kind of see the steering wheel.
The pan should last forever so that part is available used in a junk yard.
Try Worley Farm Salvage 7117 IN-60, Campbellsburg, IN 47108
(812) 883-4313
The replacement cushions are available on this site.
Apologies for reviving an old thread
Im looking to replace my seat however my current seat has the foam cast (sprayed?) directly on the seat pan and the vinyl is attached around the edge of the pan with what looks like a crimp-on strip also, my seat pan doesnt look as deep as the ones sold here
The attachment point is at the rear of the seat (rather than underneath) and consists of an adjustable boxed spring with four arms protruding forward to hold the seat up
Any idea if this is stock? And where I could get a replacement?
Found this image on the web this is the seat pan/mounting arrangement I have
Thanks
Thanks
This is the same seat we have on our 135 and in the same condition. Also don’t know if it is the float-o-matic, and also would like a replacement. Did you ever find out?
I have one in good condition that I removed years ago because I didn't like it. Probably too bulky to ship. I live in Central Maine.
