Ok im getting to the point of firing this old tractor up after a engine rebuld. couple od issues i would appreciat help on. When
adjusting the tappets like the book said with #1 piston tdc i adjust 1,2,3,5 to .012 got that done but then it says to rotate 180
degrees when i do 4,6 valves are open and i cant get .012 between the tappet and rocker arm. when i put it back together all the
timing marks lined up on the gears under the timing cover has anybody ever adjusted these what am i doing wrong. also when i
cranked it over it turn real slow then not at all so i pulled the starter and it would turn at all using jumper cables and a good
battery so i bought another starter from napa and put it on the tractor and it wont turn over either, havent had the chance to
take it off to see if it will turn over using jumper cables yet. Any suggestion on either issue. thanks
