1105 inner tie rods
JR Tx
New User
I need to replace the inner tie rods on a 1105. I've separated one of the outer tie rods but am unable to separate the inner. I attempted to use a tie rod fork tool but was unsuccessful. Is there a special tool that needs to be used in order to remove the inner tie rods? Any help is appreciated.
No other tools to make this job easier that I know
of......think your on the right track.
I turn the steering all the way left or right depending
which one you want to replace to gain a better
swing at it and use a correct size fork and a big a$$
hammer and start going to town til it pops......it will
you just have to get aggressive with it!
As a last resort use heat but don't get carried away!
Mine have always popped with no heat.
Reassemble using anti-seize to prevent this
problem in future!
Good luck
I forgot to mention......I have had more success at popping the inner tie rods loose first......seem to get a more solid impact w hammer to knock them loose leaving outside rods on. .
They also make a fork you can put on your air hammer you could try but doubt it will break it loose if that tight.
Again good luck
