ncnovice
New User
I have a MF-135 with a Perkins 3 cyl. (AG-152) engine. Do the bolt holes that go into the head from the exhaust manifold go into the water gasket? I have removed
the exhaust manifold and coolant is dripping from the front upper hole. What do I check next?
No they were all the same. Do not want to replace head unless necessary. Also having trouble with overheating periodically. Not all the time.
How clean is the radiator, maybe its plugged up. Maybe need a new thermostat. Mine with the Continental 4 cyl gasser gets a little hotter than normal when it has to work hard.
