135 fuel lieak
MH
I have a 135 diesel that has a persistent leak at the injection pump. The bottom line that goes up to an injector is leaking around the banjo bolt. I have installed a new fitting, new sealing washers and a new bolt, but it still leaks. Any tips, the sealing washers are steel and not copper, but they are the correct ones from AGCO, and are the same as what I took off. I am afraid to tighten it up any more.
