MF industrial 20
old75
I have a 20 with a FEL, works fine except that the loader is an after market and the pump is mounted on the rear and run by the PTO. I want to locate a pump to mount on the front to run the loader so I can use different pieces of equipment on the back with out the pump inter fearing. anyone know where IU can get a used pump, shaft ect for the front or even trade in the rear mounted pump on the pump for the front?, thanks
have no idea even what kind of a loader it is, it's been painted over probably several times before I bought it. it came on the tractor.
it really doesn't matter about the loader long as I can get a pump that bolts up to the two holes on the front of the tractor, I'll also need the adaptor plate to bolt on the crank shaft and shaft from the pump to the adaptor plate. probably a 15 GPM pump would do the job
Theses are all the parts need if it came with a MF32 Loader
(1) 704997M92 Shaft Assembly
(1) 704812M93 Adapter Assembly, Pump
(1) 706105M91 Pump Assembly (17 G.P.M.) (Cessna)
(3) 353693X1 Bolt (3/8 x 1-1/4" NC, Hex.)
(3) 22764X Washer (3/8" Internal Skpf.)
(2) 354642X1 Bolt (7/16 x 4-1/4" NC, Hex.)
(2) 353432X1 Washer (7/16" Lock)
Does the front of the front axle support have 2 holes (1 on each side) of the axle pivot pin, and or is the axle pivot pin in the front held in by a snap ring, or a does it have a bolt with tab holding the pivot pin in?
it is not a MF loader, I think it may be an Allied after market. I have all the parts,operators, and service manuals for the tractor, in fact I worked for the MF dealer for about three yrs back in the early 60s, all I was looking for is a good used pump and the parts that I can make fit the front end, I'm not looking to restore the thing, it's a working tractor and I can't get the full use out of it with the pump hooked to the PTO.
The part numbers I put up would make it a complete bolt on, but you seemed to missed the question I asked below the part numbers.
"Does the front of the front axle support have 2 holes (1 on each side) of the axle pivot pin, and or is the axle pivot pin in the front held in by a snap ring, or a does it have a bolt with tab holding the pivot pin in?"
If you have the front axle support that uses the bolt with a tab you would need a different shaft assembly, and a bracket that bolts to the front axle support that will also serve the purpose to mount the hydraulic pump.
Do you want to mount the pump right, or just cobble something together, and have it always give you problems?
""Do you want to mount the pump right, or just cobble something together, and have it always give you problems?
mounting it right so it will give trouble free service for a long time doesn't mean a person has to use all those high priced parts from the numbers you posted. I have things running here for the past 50 yrs with used parts that I got from the junk yard.
as I stated ,I have the MF parts manual and could order new parts, but as my first post said, I'm looking for used parts, I see no reason to spend a couple thousand dollars on parts for a two thousand tractor.. case closed.. thanks
