is there any way to tell the year of this tractor?
http://dubuque.craigslist.org/grd/5169455002.html
first one ive ever seen with a cab. kind of looking for a loader/auger tractor.
They put loaders on cab tractors all the time. We have cab tractors with loaders and the controls are plumbed into the cab.
As long as that is a factory cab there should be a FEL mounting kit available for it. The AGCO part books show a air conditioner, and a heater kit for a 165, but doesn't show anything for a cab. They only show cabs for the UK 165, but none of the cabs look like that one.
That's certainly an unusual looking cab to be fitted to an MF. Its a bit reminiscent of the
European Schluter cabs. Not sure that I'd like to have the battery right behind me
though....even in a box!!!! Clearly it would not be possible to have the battery in its
original position. Fitting a loader might be difficult with what appears to be heavy
brackets coming from the underbelly mounting point up to the front of the cab. I can't see
whether the brackets are attached to side mounting points (if fitted) or to the four bolts
on the underside. The cab front panel is well forward. This would add to the difficulty in
fitting a loader.
Good luck in your search.
DavidP, South Wales
