Massey 165 Diesel Tach Drive Oil Leak
BADDBOYY21
New User
I've noticed that I have an oil leak coming from the tach drive. It appears to be coming out of a small weep hole. I read somewhere on here that there is seal for the tach drive.
Can anyone tell me what the part # is for the seal and best place to get one?
The gasket in the tach drive cable (engine end) is part # 1037457M1.
The gasket in the tach cable (tachometer end) is part number 1031657M1.
Between the engine block, and adaptor plate for the cable the gasket is part # 731051M1, and the seal is part # 636762M1
They shouldn't be too hard to find.
(quoted from post at 09:26:35 08/12/15) The gasket in the tach drive cable (engine end) is part # 1037457M1.
I found this on ebay but the drive housing only has 3 mounting holes and mine has 4.
http://www.ebay.com/itm/MASSEY-FERG...R-DRIVE-SEAL-SET-636762M1-41568-/161780638533
