Having issues with tractor not starting have had to pull start it to get it running.
Tractor MF 360 diesel perkins- cav pump
when it's running it runs great but after a while will start sputtering and then die. Tried pull starting this morning and wouldn't start.
Have bled air out of fuel lines, changed air filter checked for obstructions. Preparing to change fuel filter.
what my best way to troubleshoot this and does anyone have idea if the fuel tank has a filter in it as well?
where is the bleed screw on the cav fuel pump? there's lots of knobs on that pump. Not sure which one is bleed screw.
