bell housing cotter pin revisited
garymck
Here is my latest attempt to replace the cotter pin on a TO35. I cut a suitable cotter pin in half and bent each part suitably to enter the hole. I applied J&B weld to the bottom halves and held them in place with welding vise grips until the mixture had dried. Seems to work so far.
This is an AH-HAH moment! Thank you. A person could cut as you say one in two, stick both ends up in there, and actually mig-weld the thing back together from underneath, I doh't doubt the JB is a good idea, but if you could actually mig-weld it, that would do it. Thanks.
After the cement dried, I can freely turn the cotter pin so that should ensure it wiggles in the field.
your method, may be my second choice,
if finding one with a eyelet just larger than the hole.
then trying to drive it up into the hole,
then spreading the legs of the cotter key,
hopefully this method will work as I am into easy,
I so forget to check the hole each time I fuel the tractor.
may have to attach a reminder sign to the fuel tank, but then I would forget to look at it.
I have enough problems remembering to turn the gas shutoff valve off each time I am leaving the tractor in the barn. carb has leaked before, that is a pain in the butt.
