MF1130 Hydraulic Problems
fredfurm
New User
I picked up a Massey Ferguson 1130 with hydraulic problems. Everything works except the 3 point lift and auxiliary. No pressure at all. What could be the problem?
There are 3 components that contribute to hydraulic problems on the 10xx series. First, the lack of maintenance to the screen in the differential sump. That, tends to take out the second potential being the charge pump under the platform. The third possibility is the radial pump on the crankshaft oon the front if the engine. My guess is the charge pump under the platform. And you will split the tractor to service it. Replace the shaft coupler when you do. They tend to wear pretty quick when the get play in them.
