Massey 44 special serial number
Mowdigger
Looking at a Massey 44 special. Is there anyway to tell by the serial number on a Massey what model it actually is? The tag is hard to read. It
appears there is the letters GR and a number starting with a 6. Can anyone help me in identifying this tractor?
Are you asking how to be sure it is a 44 Special? A Special serial number should start 44GS...if a gas, D for diesel, but there should be an S there.Your number is for a 44 gas rowcrop. A Special should have the cast front wheels, 277 engine (gas only) long frame on all models, extended rear platform on standard models.
Ben
The tag is still there. It says 44-GR 6347. The 6347 is stamped in the transmission casting also. I don't see an S anywhere in the serial number.
Sounds like a straight 44 gas rowcrop by that model number. The serial number indicates a late 40's early 50's model---there should be a brealdown of numbers years on the left side of your screen on this site.
Ben
A 44 special serial should start out looking like this
44 G1RF-gas row crop
44 G1SF- gas standard
44 K1RF- distillate row crop
44 K1SF- distillate standard
44 B1RF- low pressure gas row crop
44 B1SF- low pressure gas row crop
44 D1RF- diesel row crow
44 D1SF- diesel standard
On diesels at the end of the number their should be the letter P standing for the P.S.B. pump or the letter A for the A.P.E pump
The letter F in the serial number stands for foot clutch the letter H would stand for hand clutch
The letter S stands for standard R for row crop C for cane and W for wide axle
all of this information came directly from an original 44 special service manual
