135 diesel keeps dying
Rogi
Dads little tractor had baddd fuel in the tank and some may have gotten in the system. We cleaned the tank,new filter,new fuel pump,got it bleed out and it will run great for a few minutes then dye. I have had trouble bleeding them before,but once it came alive it would be good to the next event. Anyone tell me where to look for my trouble.. Thanks
Make sure the constant bleed orifice fitting on the top of the filter base is not plugged, will be with the return line back to the tank. Also if NAPA/Wix fuel filters are used make sure the top filter inlet groove at outer edge does not have an O ring in it by mistake, restricting the fuel flow..
