Massey 165 Fuel Sending Unit
BADDBOYY21
New User
I've searched and this seems to be a common question. However, I have not found the correct answer.
Which sending unit works in the Massey 165 Diesel, Serial #9A 43187? I bought the 897389M91. It looked like the correct one but it's for a Massey 165 UK. It didn't work.
I've found part#
1079398M91 - Sending Unit, Fuel. It says it's for the Massey 165 Diesel, all years. Would this work with the 165?
I can not seem to find the exact one online for the 165.
US Agco parts shows sending unit 511 967 M1 to fit your tank, if mounting hole is toward the rear. Before SN 643006881 the hole was next to the filler cap, sending unit part # 506 273 M1 was used as the tanks were changed. Part #s may supercede too but are worth trying..
Thanks! The mounting hole is at the rear. Do you know the ohm range of the sending unit? The gauge I have is 30-240.
