perkins diesel AD3-152 injector pump?
blue water massey
has a CAV injector pump on a 1973 MF20 industrial (same as a 135 AG)
there's an egg shaped cover plate on the side of this pump about 2 in long held on with 2 screws and sealed with a gasket
today it started to leak fuel out one side of it
when you up the RPMs it starts spraying fuel not very hard a fine mist like
do I just need a new gasket there or is there trouble further in I need to address
per your reply sounds like all it needs is a new gasket
was afraid I had internal problems
sent you a message
I'm in Canada
thank you
