massey 44 electrical issues
Kevin
Hello I have an issue going on with my massey 44. Charging system is not charging. As soon as I turn on the key the ammeter reads negative 15 amps, and when I turn the key off if takes a good 10-15 seconds for it to actually cut out the ignition. It is a 6 volt negative ground system. Anyone have any ideas?
I may be completely wrong here, but for simple electrical devices, I have come to like using PB Blaster. It removes some corrosion, lubes things, gets rid of moisture, prevents some future corrosin, and I have had it absolutely FIX some electrical switches.
