I need bottom rod bearing. When the oil warms up I loose oil pressure. I suspect bearing problems. My problem is identifying the tractor model and the motor size and kind.
There is no serial number that I can find. Behind the steering wheel a plac reads Made By Massey Harris-Ferguson Limited Toronto Ontario. There is a punched sc number on the side of the block....SC94803EVR. The oil filter is closer to the front of the moter. The origial colour of the tractor is red. I need help so I can order the right bearing.
Thanks MJ
Thanks MJ
