PTO auxillary lever
Seen a Super 90 one time with what appeared to be a factory auxiliary PTO lever bolted to the top of the transmission housing. Lever was connected to original lever end. Helped so operator did not have a problem reaching way over to engage PTO. Anyone know if these are available somewhere? Thanks, Swede
I've seen that lever too, but only on late model tractors that happened to have the Multi-Power transmission. Don't think it would be too hard to copy if none could be found at a salvage yard..
Those levers came out on the 90s with the multi-power transmissions. Would have to split tractor to install one on a standard model, but should be able to do it.
Wayne
