MF 165 hydraulic hook up
Mtractor
The cover where the PTO handle the hydraulic line coming from that cover can I use that as a pressure line for a loader?
The MF internal hydraulic pumps don't put out a lot of volume (in the 4-5 GPM range) so a loader would work pretty slow. A loader needs at least a 10+ GPM pump (unless you are in no hurry).
From the picture I am guessing that tractor has independant pto and the hydraulic line is a supply line to the clutch and brake for the pto.
If I'm correct, I don't think you want to tap into that line for a loader.
Other posters should be along soon that know more than me about the 165.
The lines pictured already go to the single or two spool valve on the tractor now, and are fed from the auxiliary pump inside on top of the separate three point hitch pump. Why not use what you have now? The three point is the lower volume of the two pumps.
