Ohiopioneer
New User
I have mf180 with Perkins diesel and 12 speed multi-power transmission. I have problem with hi-low gear range shift lever. (The muti shift lever works ok) But I lost the low end gears after I tried to pull start tractor even knowing that it would not work that way. The hi-low selector lever has to be held in place in hi range or it pops out of gear. Seems that it will not travel far enough to shift into low gear range. I would think mostly that it would be a linkage adjustment. But I see no EZ way to get to linkage.
Thanks, Ohiopioneer
Thanks, Ohiopioneer
