regulater
can someone tell me how to get the hood off a mf135. I have it loose at the back but not the front. does the grill have to come off with it?
It's a lot easier to take the hood off a 135 with the grill, and everything. Just loosen the two big bolts (one on each side) by where the radiator bolts to on the bottom, side it forward, and it's off.
11/16th A/F socket on a short extension if I remember correctly and the holes in the hood brackets are slotted.
The really fun bit is refitting the rear bolts without cross threading them, It can be done but requires a bit of patience.
thanks guys i got it off. Im going to try to fix the power steering, a man told me it was the cylinder rod broke and not pulling back when you try to turn left, it turns to the right good.he didn't know if the cylinder would come off with out taking everything else off or not.
