MF 32 Loader
Tims0566
New User
I have a MF ID 20, with a MF32 loader, I'm looking for a rebuild kit or replacement valve body for the loader. I've rebuild the bucket cylinders, and I have loader bleed down, I see seepage around nod valve Pistons. I've also cleaned the whole system with clean hydraulic oil only. I use hydraulic oil from O'Reilys as that was recommended and it meet all specs. I'm pretty sure I just need a seal kit
They don't show a seal kit for a valve body on a 32, if you are in North America log in a guest user here http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica the enter the model number. It will have the and exploded view of the valve, and the part numbers. If you can find a tag on the valve body with the manufacturers name, and the part/model number of the valve a hydraulic shop maybe able to get you a seal kit.
