Help identifying the year and model etc of my mf
Kmoran
I Just bought a mf off a old farmer claims it is a 1970s mf 150 it's gas and I think it has the Perkins motor. The block number is 37112630/3 also has p180 below that. The serial number is 9A114148 I tryed researching the serial number couldn't find anything. Any help would be appreciated thanks.
Ok thanks. Does it say if it is a mf 150 because I am trying to order parts just wanna make sure I am ordering the correct parts.
AGCO/MF didn't seem to keep "close tabs" on the MF industrial serial numbers. The industrial tractors do share most of the same parts as their agricultural tractors.
My diamond in the ruff the day I bought it not running for $1500.
I still need to put the decals, and the new grill on, but if you have a few minutes here it is at work.
https://www.youtube.com/watch?v=rudJBe2oZk4
I paid 1300 for mine it needs a starter. And
someone took the 3 point hitch lift arms off
so I gotta order them. It needs a hood sand
blasting and new paint. I like your tractor
looks good I want mine to turn out like
that.
Mine was a lot of work, it wouldn't start because they had the wrong gear on the starter. After starter I had it running in 15 minutes, it had a bad knock, and no oil pressure. Dropped the oil pan, the crankshaft was broke in-half right behind the center main bearing. When I split the tractor to fix the engine the clutch was soaked in engine oil from the beat up rear main seal, and bearing. The cab was built by my dad in 1980, the top was rusted out, and it didn't quite fit so I had to fix all that. I finally got the paint finished, and all back together. I had been working on it off, and on for almost a year.
